Продава се :
1.Бръшлес мотор 3650 / 3300KV 4pole - нов
Model - E3650 3300kv
Shaft Size - Standard 1/8" (3.2mm)
Connector Type - 4mm gold connectors
Input Voltage - 12 NiCad/NiMh MAX 3s LiPo MAX
цена 47 лв.
2. HK 3650 - 3980 Brushless motor
Motor Size: 3650
RPM/V: 3980kv
Max Load: 72A
Max volts: 11.1v 2~3s
Max Watts: 750w
Shaft Diameter: 5mm
Can Size: 540
Plug type: 4mm Bullet-connector
мотора е каран (не е нов) цена - 55лв.
3.Захранване IBM 16V / 4,5A / 65W - ново
цена 27 лв.
